Introducción
The screen is one of the most important parts of a laptop, as you won't be able to see anything you're doing without it, which is kind of the point. The disassembly isn't too complicated, there's just a lot of screws that need to be removed.
Qué necesitas
Herramienta utilizada en este paso:Metal Spudger$2.99
Using a Spudger, gently pry up the keyboard.
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
Una persona más ha completado esta guía.
