Saltar al contenido principal
ASUS X42J Motherboard Replacement
Qué necesitas
  1. ASUS X42J Motherboard Replacement, Keyboard: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Metal Spudger
    $2.99
    Comprar
    • Make sure your device is unplugged and turned off before proceeding.
    • Using a Spudger, gently pry up the keyboard.
  2. ASUS X42J Motherboard Replacement: paso 2, imagen 1 de 2 ASUS X42J Motherboard Replacement: paso 2, imagen 2 de 2
    Nylon Tipped Tweezers
    Comprar
    • Rotate the keyboard to face downward.
    • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
  3. ASUS X42J Motherboard Replacement, Disk Drive: paso 3, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
  4. ASUS X42J Motherboard Replacement: paso 4, imagen 1 de 1
    • Slide the disk drive out of the device.
  5. ASUS X42J Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 ASUS X42J Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 ASUS X42J Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
  6. ASUS X42J Motherboard Replacement: paso 6, imagen 1 de 2 ASUS X42J Motherboard Replacement: paso 6, imagen 2 de 2
    • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
  7. ASUS X42J Motherboard Replacement: paso 7, imagen 1 de 2 ASUS X42J Motherboard Replacement: paso 7, imagen 2 de 2
    Metal Spudger
    $2.99
    Comprar
    • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
  8. ASUS X42J Motherboard Replacement: paso 8, imagen 1 de 1
    • Unscrew and remove the marked screws.
  9. ASUS X42J Motherboard Replacement: paso 9, imagen 1 de 1
    • Separate the connectors.
  10. ASUS X42J Motherboard Replacement: paso 10, imagen 1 de 2 ASUS X42J Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove the motherboard from the device.
Conclusión
Robert Martinez
Miembro Desde 09/21/18
217 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 725
