Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The IO board in the ASUS X42J contains vital ports including power, ethernet, and one USB port. This is the very last thing that can come out of this device, so this will be the most time consuming guide for this device.
    • Make sure your device is unplugged and turned off before proceeding.
    • Using a Spudger, gently pry up the keyboard.
    • Rotate the keyboard to face downward.
    • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
  1. Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
    • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
  2. Slide the disk drive out of the device.
    • Slide the disk drive out of the device.
  3. Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive. Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive. Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
    • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
  4. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  5. Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard. Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
    • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
    • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
  6. Unscrew and remove the marked screws.
    • Unscrew and remove the marked screws.
  7. Separate the connectors.
    • Separate the connectors.
  8. Remove the motherboard from the device. Remove the motherboard from the device.
    • Remove the motherboard from the device.
  9. Remove the tape from the screen connector. Remove the screws from the connector.
    • Remove the tape from the screen connector.
    • Remove the screws from the connector.
  10. Pull the screen away from the mount.
    • Pull the screen away from the mount.
  11. Pull the IO board off of the mount.
    • Pull the IO board off of the mount.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 92
