Saltar al contenido principal
ASUS Vivobook S500CA Battery Replacement
Qué necesitas
  1. ASUS Vivobook S500CA Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device over to where the back plate is facing up.
  2. ASUS Vivobook S500CA Battery Replacement: paso 2, imagen 1 de 1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. ASUS Vivobook S500CA Battery Replacement: paso 3, imagen 1 de 1
    • Remove the back plate by lifting it straight up.
  4. ASUS Vivobook S500CA Battery Replacement: paso 4, imagen 1 de 1
    • Remove 9 (.5 cm) phillips screws around the edge of the battery.
  5. ASUS Vivobook S500CA Battery Replacement: paso 5, imagen 1 de 1
    • Lift up the battery to reveal the battery terminal.
  6. ASUS Vivobook S500CA Battery Replacement: paso 6, imagen 1 de 1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
Conclusión
Deric Huffman
Miembro Desde 01/17/17
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 6,002
