Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The motherboard acts like a hub for all of the components in the laptop. Sometimes a complete replacement of the motherboard is necessary. For example, liquid damage by having a drink spilled on the keyboard may require the motherboard to be replaced for optimal performance.
Fortunately, it is relatively easy to replace the motherboard since no advance tools or equipment is necessary.
Please keep in mind that if only a specific component is damaged, then it is recommended to only replace said component for budgeting reasons.
  1. Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  4. Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver. Use the black plastic spudger to remove the battery from the device. Use the black plastic spudger to remove the battery from the device.
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  5. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  6. When removing the cooling fan, carefully unplug the cable that is connected to the motherboard. Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
    • When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
    • Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
  7. Carefully remove the motherboard. You can now replace it with a new motherboard or perform any necessary modifications to it.
    • Carefully remove the motherboard.
    • You can now replace it with a new motherboard or perform any necessary modifications to it.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S5-G1, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 337
