Saltar al contenido principal
ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement
Qué necesitas
  1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Battery: paso 1, imagen 1 de 1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 2, imagen 1 de 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 2, imagen 2 de 2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 3, imagen 1 de 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 3, imagen 2 de 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 3, imagen 3 de 3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 4, imagen 1 de 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 4, imagen 2 de 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 4, imagen 3 de 3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. Aviso: los pasos 5-6 provienen de una guía que está marcada como "En progreso".
    ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: paso 5, imagen 1 de 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: paso 5, imagen 2 de 2
    • When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
    • Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
  6. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 6, imagen 1 de 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: paso 6, imagen 2 de 2
    • Carefully remove the motherboard.
    • You can now replace it with a new motherboard or perform any necessary modifications to it.
  7. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Charging Port: paso 7, imagen 1 de 1
Conclusión
Equipo
USF Tampa, Team S5-G1, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 997
