Introducción
Although it is extremely rare, the charging port on the laptop could be defective, misaligned, or broken if the laptop fails to show any signs of receiving power.
This guide should act like a "last resort" if all other methods of charging the laptop fails.
Please note that the use of soldering is required in order to remove the old charging port from the motherboard.
Qué necesitas
Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
Paso 5 Motherboard
Aviso: los pasos 5-6 provienen de una guía que está marcada como "En progreso".
When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
