Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The most common reason to replace the battery is if the laptop fails to hold a charge. This could mean that the laptop shuts off immediately when unplugged or that the battery only lasts for a short while compared to when the laptop was brand new. It is also common to remove the battery before performing any other operations on the laptop to prevent electrical damage to you and other parts on the laptop.
Over time, batteries become less efficient due to the constant charging and discharging. This is normal behavior, and it is known that batteries will lose the ability to hold a charge over a long period of time.
Partes
No se especificaron partes.
  1. Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  4. Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver. Use the black plastic spudger to remove the battery from the device. Use the black plastic spudger to remove the battery from the device.
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  5. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected. Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S5-G1, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 966
