Saltar al contenido principal
ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement
Qué necesitas
  1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    • Flip the laptop onto its backside.
    • Use a Phillips #00 screwdriver to remove the nine 1.2 mm Phillips #00 screws screws attached to the laptop backing.
  2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: paso 2, imagen 1 de 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: paso 2, imagen 2 de 2
    • Remove the laptop backing with a prying tool. Use the prying tool between the keyboard and bottom grooves.
    • Start prying from the center of the laptop and work your way around the edges of the laptop to remove the keyboard panel.
    • It is recommended to use a plastic prying tool versus a metal prying tool as it could scratch your laptop.
  3. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: paso 3, imagen 1 de 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: paso 3, imagen 2 de 2
    • Separate the laptop keyboard from the laptop backing.
    • Carefully remove the keyboard connector from the motherboard.
  4. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: paso 4, imagen 1 de 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove the two 3 mm screws attached to the laptop's hard drive metal cage using the Phillips #00 screwdriver.
    • Once the screws have been removed, gently disconnect the hard drive by pulling the hard drive away from the integrated SATA port.
  5. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: paso 5, imagen 1 de 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: paso 5, imagen 2 de 2
    • Remove the four 3 mm screws attached to hard drive metal cage using the Phillips #00 screwdriver.
    • Remove the hard drive from the bracket.
Conclusión
3 personas más completaron esta guía.
Un comentario
I replaced the original sata into a ssd but it doesnt boot to windows. It gets stuck in bios. The ssd has an os already. It appears in the storage section but not in the boot list. I have already tried to boot the ssd to my computer and it works.
Christusjohn Leoncio L Salvani - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 57
Todo El Tiempo: 1,725
