Saltar al contenido principal
ASUS VivoBook S400C Speaker Replacement
Qué necesitas
  1. ASUS VivoBook S400C Speaker Replacement, Remove the Bottom Cover: paso 1, imagen 1 de 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Speaker Replacement: paso 2, imagen 1 de 2 ASUS VivoBook S400C Speaker Replacement: paso 2, imagen 2 de 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Speaker Replacement, Disconnect the Battery: paso 3, imagen 1 de 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Speaker Replacement, Battery: paso 4, imagen 1 de 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Speaker Replacement: paso 5, imagen 1 de 1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Speaker Replacement, Hard Drive: paso 6, imagen 1 de 1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Speaker Replacement: paso 7, imagen 1 de 1
    • Pull left and lift out the hard drive.
  8. ASUS VivoBook S400C Speaker Replacement, LED Board: paso 8, imagen 1 de 3 ASUS VivoBook S400C Speaker Replacement, LED Board: paso 8, imagen 2 de 3 ASUS VivoBook S400C Speaker Replacement, LED Board: paso 8, imagen 3 de 3
    • Disconnect the ribbon cable connecting the LED daughterboard and the motherboard by lifting the white tab on the LED side of the cable.
  9. ASUS VivoBook S400C Speaker Replacement: paso 9, imagen 1 de 2 ASUS VivoBook S400C Speaker Replacement: paso 9, imagen 2 de 2
    • Pull out the ribbon cable on the LED side by pulling on the blue tab.
  10. ASUS VivoBook S400C Speaker Replacement: paso 10, imagen 1 de 3 ASUS VivoBook S400C Speaker Replacement: paso 10, imagen 2 de 3 ASUS VivoBook S400C Speaker Replacement: paso 10, imagen 3 de 3
    • The LED board is held in place by a hook on the left end and a latch on the right.
    • Press the latch with a spudger while lifting with a fingernail.
    • Pull the LED board to the right to clear the left-hand hook.
  11. ASUS VivoBook S400C Speaker Replacement, Speakers: paso 11, imagen 1 de 2 ASUS VivoBook S400C Speaker Replacement, Speakers: paso 11, imagen 2 de 2
    • Pull out the black cable connecting the motherboard to the speakers.
  12. ASUS VivoBook S400C Speaker Replacement: paso 12, imagen 1 de 2 ASUS VivoBook S400C Speaker Replacement: paso 12, imagen 2 de 2
    • Deroute the speaker wire from the motherboard to the left speaker.
  13. ASUS VivoBook S400C Speaker Replacement: paso 13, imagen 1 de 3 ASUS VivoBook S400C Speaker Replacement: paso 13, imagen 2 de 3 ASUS VivoBook S400C Speaker Replacement: paso 13, imagen 3 de 3
    • Using a metal opening tool, pry off the left speaker.
    • A fairly strong adhesive is used between the speakers and the body of the laptop, requiring considerable force to take apart. Work slowly and use caution when working near the delicate wires connecting the two speakers.
  14. ASUS VivoBook S400C Speaker Replacement: paso 14, imagen 1 de 2 ASUS VivoBook S400C Speaker Replacement: paso 14, imagen 2 de 2
    • Deroute the wires from the left speaker to the right.
  15. ASUS VivoBook S400C Speaker Replacement: paso 15, imagen 1 de 2 ASUS VivoBook S400C Speaker Replacement: paso 15, imagen 2 de 2
    • Continue to deroute the speaker wire to the right speaker.
  16. ASUS VivoBook S400C Speaker Replacement: paso 16, imagen 1 de 3 ASUS VivoBook S400C Speaker Replacement: paso 16, imagen 2 de 3 ASUS VivoBook S400C Speaker Replacement: paso 16, imagen 3 de 3
    • Using a metal opening tool, pry off the right speaker.
    • It bears repeating that a fairly strong adhesive is used between the speakers and the body of the laptop, requiring considerable force to take apart.
Conclusión
Una persona más ha completado esta guía.
Bryan Chung
Miembro Desde 10/18/19
437 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 1,077
