Saltar al contenido principal
ASUS VivoBook S400C LED Board Replacement
Qué necesitas
  1. ASUS VivoBook S400C LED Board Replacement, Remove the Bottom Cover: paso 1, imagen 1 de 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C LED Board Replacement: paso 2, imagen 1 de 2 ASUS VivoBook S400C LED Board Replacement: paso 2, imagen 2 de 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C LED Board Replacement, Disconnect the Battery: paso 3, imagen 1 de 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C LED Board Replacement, LED Board: paso 4, imagen 1 de 3 ASUS VivoBook S400C LED Board Replacement, LED Board: paso 4, imagen 2 de 3 ASUS VivoBook S400C LED Board Replacement, LED Board: paso 4, imagen 3 de 3
    • Disconnect the ribbon cable connecting the LED daughterboard and the motherboard by lifting the white tab on the LED side of the cable.
  5. ASUS VivoBook S400C LED Board Replacement: paso 5, imagen 1 de 2 ASUS VivoBook S400C LED Board Replacement: paso 5, imagen 2 de 2
    • Pull out the ribbon cable on the LED side by pulling on the blue tab.
  6. ASUS VivoBook S400C LED Board Replacement: paso 6, imagen 1 de 3 ASUS VivoBook S400C LED Board Replacement: paso 6, imagen 2 de 3 ASUS VivoBook S400C LED Board Replacement: paso 6, imagen 3 de 3
    • The LED board is held in place by a hook on the left end and a latch on the right.
    • Press the latch with a spudger while lifting with a fingernail.
    • Pull the LED board to the right to clear the left-hand hook.
Conclusión
Jerry Wheeler
Miembro Desde 03/21/22
71,749 Reputación
71 Guías creadas
Equipo
Oregonians Miembro de Oregonians
Community
8 Miembros
189 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 67
