Saltar al contenido principal
ASUS VivoBook S400C Hard Drive Replacement
Qué necesitas
  1. ASUS VivoBook S400C Hard Drive Replacement, Remove the Bottom Cover: paso 1, imagen 1 de 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Hard Drive Replacement: paso 2, imagen 1 de 2 ASUS VivoBook S400C Hard Drive Replacement: paso 2, imagen 2 de 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Hard Drive Replacement, Disconnect the Battery: paso 3, imagen 1 de 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Hard Drive Replacement, Battery: paso 4, imagen 1 de 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Hard Drive Replacement: paso 5, imagen 1 de 1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Hard Drive Replacement: paso 7, imagen 1 de 1
    • Pull left and lift out the hard drive.
Conclusión
Tiana Curry
Miembro Desde 10/18/19
85 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 1,996
