Saltar al contenido principal
ASUS VivoBook S400C Display Assembly Replacement
Qué necesitas
  1. ASUS VivoBook S400C Display Assembly Replacement, Remove the Bottom Cover: paso 1, imagen 1 de 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Display Assembly Replacement: paso 2, imagen 1 de 2 ASUS VivoBook S400C Display Assembly Replacement: paso 2, imagen 2 de 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Display Assembly Replacement, Disconnect the Battery: paso 3, imagen 1 de 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Display Assembly Replacement, Heat Shield: paso 4, imagen 1 de 2 ASUS VivoBook S400C Display Assembly Replacement, Heat Shield: paso 4, imagen 2 de 2
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  5. ASUS VivoBook S400C Display Assembly Replacement, Display Assembly: paso 5, imagen 1 de 1
    • Remove the black tape securing the keyboard ribbon cable to the display connector.
    • Fold the ribbon cable the opposite way, resecuring it to the hard drive to keep it out of the way.
  6. ASUS VivoBook S400C Display Assembly Replacement: paso 6, imagen 1 de 2 ASUS VivoBook S400C Display Assembly Replacement: paso 6, imagen 2 de 2
    • Peel off the clear tape from the motherboard display connector.
  7. ASUS VivoBook S400C Display Assembly Replacement: paso 7, imagen 1 de 2 ASUS VivoBook S400C Display Assembly Replacement: paso 7, imagen 2 de 2
    • Position spudgers on the white tabs on either side of the connector and push evenly to unplug the display.
  8. ASUS VivoBook S400C Display Assembly Replacement: paso 8, imagen 1 de 3 ASUS VivoBook S400C Display Assembly Replacement: paso 8, imagen 2 de 3 ASUS VivoBook S400C Display Assembly Replacement: paso 8, imagen 3 de 3
    • Peel off the three pieces of black tape securing the display cable to the motherboard.
    • Deroute the cable from the channel it sits in.
    • Move the cable to the side, out of the way.
  9. ASUS VivoBook S400C Display Assembly Replacement: paso 9, imagen 1 de 3 ASUS VivoBook S400C Display Assembly Replacement: paso 9, imagen 2 de 3 ASUS VivoBook S400C Display Assembly Replacement: paso 9, imagen 3 de 3
    • Use a spudger to release the cables from the wifi card.
  10. ASUS VivoBook S400C Display Assembly Replacement: paso 10, imagen 1 de 3 ASUS VivoBook S400C Display Assembly Replacement: paso 10, imagen 2 de 3 ASUS VivoBook S400C Display Assembly Replacement: paso 10, imagen 3 de 3
    • Lift the tapes securing the wires to the motherboard.
    • Move the wires to the side out of the way.
  11. ASUS VivoBook S400C Display Assembly Replacement, Disconnect the Hinges: paso 11, imagen 1 de 2 ASUS VivoBook S400C Display Assembly Replacement, Disconnect the Hinges: paso 11, imagen 2 de 2
    • Remove the two screws securing the hinge on the left.
    • Pry the hinge up by hand to a 90 degree angle.
  12. ASUS VivoBook S400C Display Assembly Replacement: paso 12, imagen 1 de 2 ASUS VivoBook S400C Display Assembly Replacement: paso 12, imagen 2 de 2
    • Remove the two screws securing the hinge on the right.
  13. ASUS VivoBook S400C Display Assembly Replacement, Remove the Display: paso 13, imagen 1 de 3 ASUS VivoBook S400C Display Assembly Replacement, Remove the Display: paso 13, imagen 2 de 3 ASUS VivoBook S400C Display Assembly Replacement, Remove the Display: paso 13, imagen 3 de 3
    • Lift the base of the laptop from the front.
    • Raise it to a 90 degree angle.
    • Slide it forward slightly to clear the hinges.
    • The display is now free.
Conclusión
Jerry Wheeler
Miembro Desde 03/21/22
72,268 Reputación
71 Guías creadas
Equipo
Oregonians Miembro de Oregonians
Community
Miembros de 8
189 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 304
