Saltar al contenido principal
ASUS VivoBook S300CA-BBI5T01 Fan Replacement
Qué necesitas
  1. ASUS VivoBook S300CA-BBI5T01 Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: paso 2, imagen 1 de 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: paso 3, imagen 1 de 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: paso 4, imagen 1 de 1
    • Remove the following 6 screws:
    • Two 5 mm screws holding the fan down.
    • Four 3 mm screws holding the heat sink down
    • Removing one of these screws voids the device's warranty.
  5. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: paso 5, imagen 1 de 1
    • Carefully disconnect the only sliding connector by using a plastic opening tool to pry the connector out.
  6. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: paso 6, imagen 1 de 1
    • Remove the fan and heat sink by lifting it upwards.
  7. ASUS VivoBook S300CA-BBI5T01 Fan Replacement: paso 7, imagen 1 de 2 ASUS VivoBook S300CA-BBI5T01 Fan Replacement: paso 7, imagen 2 de 2
    • Remove the tape holding the fan and heat sink together.
    • Before reassembly it is essential to clean off the old thermal paste from the processor and the heatsink and to apply new. How to apply thermal paste explains how.
Conclusión
Keith Rachels
Miembro Desde 03/04/16
595 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,772
