Saltar al contenido principal
ASUS VivoBook S300CA-BBI5T01 Battery Replacement
Qué necesitas
  1. ASUS VivoBook S300CA-BBI5T01 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: paso 2, imagen 1 de 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: paso 3, imagen 1 de 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the 7 screws holding the battery in place.
    • Six 3 mm Phillips head screws
    • One 5 mm Phillips head screw
  5. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the one flat topped wire connector by carefully using a plastic opening tool to pry up both sides and then lifting the connector from its socket.
  6. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: paso 6, imagen 1 de 1
    • Slide out the battery.
Conclusión
Una persona más ha completado esta guía.
Keith Rachels
Miembro Desde 03/04/16
595 Reputación
5 Guías creadas
Equipo
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 3,679
