Saltar al contenido principal
ASUS VivoBook Flip TP501U Battery Replacement
Qué necesitas
  1. ASUS VivoBook Flip TP501U Battery Replacement, Keyboard Panel: paso 1, imagen 1 de 2 ASUS VivoBook Flip TP501U Battery Replacement, Keyboard Panel: paso 1, imagen 2 de 2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Battery Replacement: paso 2, imagen 1 de 1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Battery Replacement: paso 3, imagen 1 de 1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U Battery Replacement, Battery: paso 4, imagen 1 de 2 ASUS VivoBook Flip TP501U Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the white ribbon cable shown by pulling on the blue tab.
  5. ASUS VivoBook Flip TP501U Battery Replacement: paso 5, imagen 1 de 2 ASUS VivoBook Flip TP501U Battery Replacement: paso 5, imagen 2 de 2
    • Remove the black cable found beneath the white ribbon cable that you just removed.
  6. ASUS VivoBook Flip TP501U Battery Replacement: paso 6, imagen 1 de 1
    • Disconnect the battery from the motherboard by unplugging the wire bundle shown.
  7. ASUS VivoBook Flip TP501U Battery Replacement: paso 7, imagen 1 de 2 ASUS VivoBook Flip TP501U Battery Replacement: paso 7, imagen 2 de 2
    • Unscrew the 3/16 inch long screw that holds the battery to the chassis using a #00 Phillips Screwdriver.
    • Lift the battery from the chassis.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 50
Todo El Tiempo: 1,986
