Saltar al contenido principal
ASUS U57A-BBL4 Front Panel Assembly Replacement
Qué necesitas
  1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 2, imagen 1 de 1
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 3, imagen 1 de 1
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: paso 4, imagen 1 de 2 ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: paso 4, imagen 2 de 2
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 5, imagen 1 de 1
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 6, imagen 1 de 1
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 7, imagen 1 de 2 ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 7, imagen 2 de 2
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 8, imagen 1 de 2 ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 8, imagen 2 de 2
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 9, imagen 1 de 3 ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 9, imagen 2 de 3 ASUS U57A-BBL4 Front Panel Assembly Replacement: paso 9, imagen 3 de 3
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 199
