Saltar al contenido principal
ASUS U57A-BBL4 Display Assembly Replacement
Qué necesitas
  1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 2 ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: paso 1, imagen 2 de 2
    • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
  2. ASUS U57A-BBL4 Display Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
  3. ASUS U57A-BBL4 Display Assembly Replacement: paso 3, imagen 1 de 1
    • Starting from one of the corners, use your fingers to pry the bezel from the screen.
    • There is a popping sound when the bezel is loosened from the screen.
  4. ASUS U57A-BBL4 Display Assembly Replacement: paso 4, imagen 1 de 3 ASUS U57A-BBL4 Display Assembly Replacement: paso 4, imagen 2 de 3 ASUS U57A-BBL4 Display Assembly Replacement: paso 4, imagen 3 de 3
    • Remove the top two 2 mm Phillips head screws.
    • Remove the four 2 mm Phillips head screws on the bottom.
    • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
    • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
  5. ASUS U57A-BBL4 Display Assembly Replacement: paso 5, imagen 1 de 2 ASUS U57A-BBL4 Display Assembly Replacement: paso 5, imagen 2 de 2
    • Don't tear off the bottom of the screen or you might damage the connector cable.
    • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
  6. ASUS U57A-BBL4 Display Assembly Replacement: paso 6, imagen 1 de 2 ASUS U57A-BBL4 Display Assembly Replacement: paso 6, imagen 2 de 2
    • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
    • Gently slide the cable out of the ridges to free the screen from the casing.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 276
