Saltar al contenido principal
ASUS U30SD-XA1 RAM Replacement
Qué necesitas
  1. ASUS U30SD-XA1 RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Before removing the RAM, shut down your laptop and unplug the power adapter.
    • Turn the laptop over onto a flat surface.
  2. ASUS U30SD-XA1 RAM Replacement: paso 2, imagen 1 de 1
    • At the top center on the back of the device, you will see a small square panel.
    • Use a Phillips screwdriver to remove two screws located on the panel.
  3. ASUS U30SD-XA1 RAM Replacement: paso 3, imagen 1 de 2 ASUS U30SD-XA1 RAM Replacement: paso 3, imagen 2 de 2
    • Ground yourself from electrostatic discharge by touching any metal objects or use your anti-static gloves.
    • System memories are very sensitive to static electricity.
    • Push apart the latches on either side of the slot that hold the RAM in place, but gently.
    • Use firm pressure as needed. You will hear the RAM pop out of the slot.
    • Take the RAM stick out carefully, and set it aside on an anti-static surface.
  4. ASUS U30SD-XA1 RAM Replacement: paso 4, imagen 1 de 1
    • To replace the RAM, take and hold the new RAM by the sides, with the gold edge facing down towards the device.
    • Make sure your hands are clean and do not let your fingerprints get on the memory.
    • Line up the top corners of the new RAM with the top edges of the now empty panel.
    • Slide the RAM into the slot until it's firmly in place.
    • Once you hear the RAM stick click into place, you'll know you did it correctly.
    • Now just screw the panel door back on and you're finished!
Conclusión
Your new ASUS U30SD-XA1 RAM is ready to go. Now your device should run and work faster!
2 personas más completaron esta guía.
Julie M Paul
Miembro Desde 07/17/15
164 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 3-1, Rauch SU 2015 Miembro de Texas Tech, Team 3-1, Rauch SU 2015
TTU-RAUCH-SU15S3G1
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 56
Todo El Tiempo: 1,386
