Saltar al contenido principal
ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement
Qué necesitas
  1. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: paso 1, imagen 1 de 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: paso 1, imagen 2 de 2
    • Remove the ten 10.7 mm screws using a Phillips #0 screwdriver from the back of the laptop.
  2. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 2, imagen 1 de 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 2, imagen 2 de 2
    • Using a heavy-duty spudger, pry the back cover up from the frame and completely remove.
  3. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 3, imagen 1 de 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 3, imagen 2 de 2
    • Remove the two 4.7 mm screws with the Phillips #0 screwdriver.
  4. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 4, imagen 1 de 3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 4, imagen 2 de 3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 4, imagen 3 de 3
    • Using a spudger or fingernail, flip up the white plastic latch securing the ribbon cable.
    • After the latch is released remove the ribbon cable and clear it from the board.
  5. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 5, imagen 1 de 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: paso 5, imagen 2 de 2
    • Remove the board itself by carefully pulling the board up then away from the rest of the computer.
Conclusión
Wyatt Scott
Miembro Desde 11/01/18
136 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G3, Harley Fall 2018 Miembro de IUPUI, Team S2-G3, Harley Fall 2018
IUPUI-HARLEY-F18S2G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 976
