Saltar al contenido principal
ASUS ROG Zephyrus M15GU205L Display Cable Replacement
Qué necesitas
  1. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Battery: paso 1, imagen 1 de 2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Battery: paso 1, imagen 2 de 2
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: paso 2, imagen 1 de 2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: paso 3, imagen 1 de 1
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: paso 4, imagen 1 de 2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the computer.
  6. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Display Cable: paso 6, imagen 1 de 1
    • Once the back has been removed, locate this connection cable.
    • Check to see if the connector is in the pin slot; if not, locate the connector.
  7. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: paso 7, imagen 1 de 1
    • If the connection is loose, connect the pins into the slot.
    • Once the connector is connected, do these steps in reverse.
Conclusión
Yahir Donis
Miembro Desde 09/07/23
339 Reputación
2 Guías creadas
Equipo
Gateway, Team 69-69, Gonzalez Fall 2023 Miembro de Gateway, Team 69-69, Gonzalez Fall 2023
GCC-GONZALEZ-F23S69G69
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 182
