Saltar al contenido principal
ASUS ROG Strix GL503VD-DB71 Fan Replacement
Qué necesitas
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: paso 1, imagen 1 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: paso 1, imagen 2 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: paso 1, imagen 3 de 3
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: paso 2, imagen 1 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: paso 2, imagen 2 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: paso 2, imagen 3 de 3
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: paso 3, imagen 1 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: paso 3, imagen 2 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: paso 3, imagen 3 de 3
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - Contestar
WTF i can find a 12 V for my GL503V
mrparisalexandre - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 34
Todo El Tiempo: 4,545
