Saltar al contenido principal
ASUS ROG G750JW-RS72-CB RAM Replacement
Qué necesitas
  1. ASUS ROG G750JW-RS72-CB RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB RAM Replacement: paso 2, imagen 1 de 1
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB RAM Replacement, RAM: paso 3, imagen 1 de 2 ASUS ROG G750JW-RS72-CB RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Open flap in center and underneath you will find a screw, remove the 5.2mm screw with a Phillips #0 screwdriver.
  4. ASUS ROG G750JW-RS72-CB RAM Replacement: paso 4, imagen 1 de 2 ASUS ROG G750JW-RS72-CB RAM Replacement: paso 4, imagen 2 de 2
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  5. ASUS ROG G750JW-RS72-CB RAM Replacement: paso 5, imagen 1 de 1
    • This exposes two hard drive caddies.
    • This also exposes two RAM slots.
  6. ASUS ROG G750JW-RS72-CB RAM Replacement: paso 6, imagen 1 de 1
    • Push the metal tabs outward that are located on both sides of the top ram.
    • Remove the RAM from the slot.
    • Repeat with bottom RAM
  7. ASUS ROG G750JW-RS72-CB RAM Replacement: paso 7, imagen 1 de 2 ASUS ROG G750JW-RS72-CB RAM Replacement: paso 7, imagen 2 de 2
    • Align new RAM's key with the slot.
    • Place RAM in slot at a 45 degree angle downward, until the teeth are hidden inside of the socket itself.
    • Push down on RAM until a clicking sound is heard, meaning it is in place.
    • Repeat with top RAM
Conclusión
To reassemble your device, follow Steps 1-4 in reverse order.
Una persona más ha completado esta guía.
Ellie Moran
Miembro Desde 01/22/18
142 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G5, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
Miembros de 4
5 Guías creadas
1Guía Comentario
What about replacing the two internal RAM Modules?
Latiron London - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 1,358
