Saltar al contenido principal
ASUS ROG G750JW-RS72-CB Hard Drive Replacement
Qué necesitas
  1. ASUS ROG G750JW-RS72-CB Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: paso 2, imagen 1 de 1
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  4. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: paso 4, imagen 1 de 1
    • Unscrew the 5.2mm screw underneath the flap.
  5. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: paso 5, imagen 1 de 2 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: paso 5, imagen 2 de 2
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: paso 6, imagen 1 de 3 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: paso 6, imagen 2 de 3 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: paso 6, imagen 3 de 3
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
Conclusión
Joseph Rockwell
Miembro Desde 01/22/18
243 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S11-G5, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 708
