Saltar al contenido principal
ASUS ROG G750JW-RS72-CB Display Assembly Replacement
Qué necesitas
  1. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 2, imagen 1 de 1
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  4. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 4, imagen 1 de 1
    • Unscrew the 5.2mm screw underneath the flap.
  5. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 5, imagen 1 de 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 5, imagen 2 de 2
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 6, imagen 1 de 3 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 6, imagen 2 de 3 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 6, imagen 3 de 3
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
  7. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Display Assembly: paso 7, imagen 1 de 1
    • Remove the 8.5mm screws holding the bottom half of the laptop together.
  8. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 8, imagen 1 de 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 8, imagen 2 de 2
    • Take a metal separater and gently pry open the back end of the laptop halves.
  9. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 9, imagen 1 de 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 9, imagen 2 de 2
    • Remove the connector connecting the screen and the motherboard
  10. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 10, imagen 1 de 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 10, imagen 2 de 2
    • Unscrew the 6.8mm screws holding the hinges of the screen to the bottom half of the computer.
    • Detach the screen from the hinges of the laptop.
    • Be careful not to damage the connecting wires when detaching the screen.
  11. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 11, imagen 1 de 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 11, imagen 2 de 2
    • Use a metal separator to carefully separate the bottom half of the laptop.
  12. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: paso 12, imagen 1 de 1
    • Gently unplug the cables connecting the screen to the motherboard.
    • The display assembly can now be freely separated.
Conclusión
5 personas más completaron esta guía.
Sully Chen
Miembro Desde 01/22/18
525 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S11-G5, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
Miembros de 4
5 Guías creadas
1Guía Comentario
Super helpful.
Upon re-pasting GPU I noticed that not only GPU chip was covered in thermal paste surrounding chips were literately covered with thermal paste to is that normal?
Timepusher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 28
Todo El Tiempo: 1,993
