Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The speaker will come off with the speaker cover, but it is not necessary to follow this guide to continue disassembly of the device.
Partes
No se especificaron partes.
  1. Gently pry the back hinge cover piece away from the device.
    • Gently pry the back hinge cover piece away from the device.
  2. Disconnect the speaker cable from the motherboard.
    • Disconnect the speaker cable from the motherboard.
  3. Remove the four screws using a Phillips #0 screwdriver.
    • Remove the four screws using a Phillips #0 screwdriver.
    • Remove the speaker from the device.
    • One of the screws may be hidden underneath the barcode sticker.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 87
