Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Before removing the RAM sticks, be sure you have a clean surface to place them on as they are sensitive to dust and dirt.
Partes
No se especificaron partes.
  1. Lift the screw cover and remove the screw using a Phillips #0 screwdriver. Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. Remove the RAM cover by lifting the screw cover and pulling away firmly.
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. Push outwards on the clips to release the RAM stick. The stick should pop up at an angle. Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. Pull out the RAM stick carefully.
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. Repeat steps 3-4 to remove the second RAM stick.
    • Repeat steps 3-4 to remove the second RAM stick.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 223
