Saltar al contenido principal
ASUS R554L Battery Replacement
Qué necesitas
  1. ASUS R554L Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop so the bottom is facing upward.
    • Remove ten screws using a Phillips #0 screwdriver.
  2. ASUS R554L Battery Replacement: paso 2, imagen 1 de 3 ASUS R554L Battery Replacement: paso 2, imagen 2 de 3 ASUS R554L Battery Replacement: paso 2, imagen 3 de 3
    • Using your fingertips, carefully pull the backplate in an upright direction.
    • Continue along the edges until the backplate is fully removed.
    • It's normal to hear cracking while pulling up on the plate.
  3. ASUS R554L Battery Replacement: paso 3, imagen 1 de 3 ASUS R554L Battery Replacement: paso 3, imagen 2 de 3 ASUS R554L Battery Replacement: paso 3, imagen 3 de 3
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    • Pull up on the cable connected to the motherboard to remove.
    • Remove the battery from the bay.
  4. ASUS R554L Battery Replacement: paso 4, imagen 1 de 3 ASUS R554L Battery Replacement: paso 4, imagen 2 de 3 ASUS R554L Battery Replacement: paso 4, imagen 3 de 3
    • Place the new battery in the bay.
    • Install the battery cable to the motherboard, applying pressure in a downward direction.
    • Screws the screws back in using a Phillips #0 screwdriver.
  5. ASUS R554L Battery Replacement: paso 5, imagen 1 de 3 ASUS R554L Battery Replacement: paso 5, imagen 2 de 3 ASUS R554L Battery Replacement: paso 5, imagen 3 de 3
    • Align the backplate.
    • Starting with the upper right corner, apply pressure in a downward angle.
    • Repeat the process around the backplate until it's fully secure.
  6. ASUS R554L Battery Replacement: paso 6, imagen 1 de 2 ASUS R554L Battery Replacement: paso 6, imagen 2 de 2
    • Screw the backplate screws back in using a Phillips #0 screwdriver.
Conclusión
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
Una persona más ha completado esta guía.
Joshua Chavez
Miembro Desde 01/31/22
160 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 49
Ultimos 30 días: 270
Todo El Tiempo: 4,516
