Introducción
Before proceeding with an SSD upgrade or replacement in a laptop, it's crucial to check compatibility with the laptop model, ensure proper backup of important data, and consider factors such as budget and specific performance requirements.
Qué necesitas
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
Casi Terminas!
To reassemble your device, Follow these instructions in reverse order.
Conclusión
