Saltar al contenido principal
ASUS Q524U Hard Drive Replacement
Qué necesitas
  1. ASUS Q524U Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
  2. ASUS Q524U Hard Drive Replacement: paso 2, imagen 1 de 3 ASUS Q524U Hard Drive Replacement: paso 2, imagen 2 de 3 ASUS Q524U Hard Drive Replacement: paso 2, imagen 3 de 3
    • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
  3. ASUS Q524U Hard Drive Replacement: paso 3, imagen 1 de 1
    • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
  4. ASUS Q524U Hard Drive Replacement: paso 4, imagen 1 de 1
    • Remove the back panel, exposing the motherboard.
    • Set the panel aside, skin up to avoid scratches.
  5. ASUS Q524U Hard Drive Replacement: paso 5, imagen 1 de 1
    • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
    • The hard-drive is located in the bottom left corner of the motherboard.
  6. ASUS Q524U Hard Drive Replacement: paso 6, imagen 1 de 2 ASUS Q524U Hard Drive Replacement: paso 6, imagen 2 de 2
    • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 90
Todo El Tiempo: 2,404
