Saltar al contenido principal
ASUS Q524U Hard Drive Replacement
Qué necesitas
  1. ASUS Q524U Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
  2. ASUS Q524U Hard Drive Replacement: paso 2, imagen 1 de 3 ASUS Q524U Hard Drive Replacement: paso 2, imagen 2 de 3 ASUS Q524U Hard Drive Replacement: paso 2, imagen 3 de 3
    • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
  3. ASUS Q524U Hard Drive Replacement: paso 3, imagen 1 de 1
    • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
  4. ASUS Q524U Hard Drive Replacement: paso 4, imagen 1 de 1
    • Remove the back panel, exposing the motherboard.
    • Set the panel aside, skin up to avoid scratches.
  5. ASUS Q524U Hard Drive Replacement: paso 5, imagen 1 de 1
    • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
    • The hard-drive is located in the bottom left corner of the motherboard.
  6. ASUS Q524U Hard Drive Replacement: paso 6, imagen 1 de 2 ASUS Q524U Hard Drive Replacement: paso 6, imagen 2 de 2
    • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 41
Todo El Tiempo: 3,246
