Saltar al contenido principal
ASUS Q405U Wifi Card Replacement
Qué necesitas
  1. ASUS Q405U Wifi Card Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Wifi Card Replacement: paso 2, imagen 1 de 1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Wifi Card Replacement: paso 3, imagen 1 de 3 ASUS Q405U Wifi Card Replacement: paso 3, imagen 2 de 3 ASUS Q405U Wifi Card Replacement: paso 3, imagen 3 de 3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Wifi Card Replacement, Battery: paso 4, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
  5. ASUS Q405U Wifi Card Replacement: paso 5, imagen 1 de 1
    • Once all screws are removed, lift the battery out from the base of the computer.
  6. ASUS Q405U Wifi Card Replacement, Wifi Card: paso 6, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove the 0.8 mm screw securing the Wi-Fi card to the device.
Conclusión
Jeremiah Baselice
Miembro Desde 10/25/21
569 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 2-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G8
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 370
