Saltar al contenido principal
ASUS Q405U Battery Replacement
Qué necesitas
  1. ASUS Q405U Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Battery Replacement: paso 2, imagen 1 de 1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Battery Replacement: paso 3, imagen 1 de 3 ASUS Q405U Battery Replacement: paso 3, imagen 2 de 3 ASUS Q405U Battery Replacement: paso 3, imagen 3 de 3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
  5. ASUS Q405U Battery Replacement: paso 5, imagen 1 de 1
    • Once all screws are removed, lift the battery out from the base of the computer.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 personas más completaron esta guía.
Jeremiah Baselice
Miembro Desde 10/25/21
569 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 2-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G8
4 Miembros
5 Guías creadas
Un comentario
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 60
Todo El Tiempo: 1,559
