Saltar al contenido principal
ASUS Q400A-BHI7N03 Screen Replacement
Qué necesitas
  1. ASUS Q400A-BHI7N03 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Flip the laptop on its back side with the battery facing toward you.
    • Slide the tabs with lock/unlock symbol, to the unlock position.
    • Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
  2. ASUS Q400A-BHI7N03 Screen Replacement: paso 2, imagen 1 de 1
    • Lift the two black plastic circles off the screen using the plastic spudger.
    • Unscrew the two 8mm Phillips #0 screws.
  3. ASUS Q400A-BHI7N03 Screen Replacement: paso 3, imagen 1 de 1
    • Pry the front edges of the screen using the spudger.
  4. ASUS Q400A-BHI7N03 Screen Replacement: paso 4, imagen 1 de 1
    • Remove the four black 8mm Phillips #0 screws and set them aside.
  5. ASUS Q400A-BHI7N03 Screen Replacement: paso 5, imagen 1 de 1
    • Pry the LCD from the front frame.
  6. ASUS Q400A-BHI7N03 Screen Replacement: paso 6, imagen 1 de 1
    • Pull the gold ribbon cable to disconnect the screen from the laptop.
Conclusión
3 personas más completaron esta guía.
Wan Ahmad Aiman
Miembro Desde 10/31/18
403 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G3, Harley Fall 2018 Miembro de IUPUI, Team S1-G3, Harley Fall 2018
IUPUI-HARLEY-F18S1G3
3 Miembros
2 Guías creadas
Un comentario
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
Daniel Ventura Avalos - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 569
