Introducción
It is a common issue among ASUS Q400A laptops to refrain from charging. Among battery and charger issues, it is likely that the power jack isn't operating correctly. The following is a guide explaining how to gain access to the power jack for replacement.
Qué necesitas
Flip laptop over with the battery facing toward you.
Slide both tabs with the lock/unlock symbol, near the battery on the right of the notebook, to the unlock position.
Grab the top edge of the battery & lift upward to relieve the battery from its slot.
Unscrew the two black 8mm Phillips #0 screws.
Firmly grasp each antenna head with a pair of blunt tweezers and detach it by lifting up straight.
Una persona más ha completado esta guía.
