Saltar al contenido principal
ASUS Q324UA-BHI7T17 CPU Fan Replacement
Qué necesitas
  1. ASUS Q324UA-BHI7T17 CPU Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 2, imagen 1 de 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 2, imagen 2 de 2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 3, imagen 1 de 1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 5, imagen 1 de 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 5, imagen 2 de 2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: paso 6, imagen 1 de 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: paso 6, imagen 2 de 2
    • Using a Phillips #0 screwdriver remove the six screws holding the CPU Fan and Heatsink in place.
    • All six screws are 0.4 cm in length and have a 0.5 cm head diameter.
  7. ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 7, imagen 1 de 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 7, imagen 2 de 2
    Comprar
    • Next, carefully remove the sliding connector that connect the CPU Fan and the laptop together using the tweezers.
  8. ASUS Q324UA-BHI7T17 CPU Fan Replacement: paso 8, imagen 1 de 1
    • Remove the CPU Fan and Heatsink by simply lifting upwards.
Conclusión
Scott Santiago
Miembro Desde 10/17/17
534 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,047
