Saltar al contenido principal
ASUS Q302L Fan Replacement
Qué necesitas
  1. ASUS Q302L Fan Replacement, Back Case: paso 1, imagen 1 de 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Fan Replacement: paso 2, imagen 1 de 3 ASUS Q302L Fan Replacement: paso 2, imagen 2 de 3 ASUS Q302L Fan Replacement: paso 2, imagen 3 de 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Fan Replacement: paso 3, imagen 1 de 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Fan Replacement, Fan: paso 4, imagen 1 de 2 ASUS Q302L Fan Replacement, Fan: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  5. ASUS Q302L Fan Replacement: paso 5, imagen 1 de 3 ASUS Q302L Fan Replacement: paso 5, imagen 2 de 3 ASUS Q302L Fan Replacement: paso 5, imagen 3 de 3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  6. ASUS Q302L Fan Replacement: paso 6, imagen 1 de 2 ASUS Q302L Fan Replacement: paso 6, imagen 2 de 2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
Conclusión
Kerolus Gerges
Miembro Desde 03/02/17
219 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S13-G4, Cagle Spring 2017 Miembro de USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 755
