Saltar al contenido principal
ASUS Q302L Battery Replacement
Qué necesitas
  1. ASUS Q302L Battery Replacement, Back Case: paso 1, imagen 1 de 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Battery Replacement: paso 2, imagen 1 de 3 ASUS Q302L Battery Replacement: paso 2, imagen 2 de 3 ASUS Q302L Battery Replacement: paso 2, imagen 3 de 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Battery Replacement: paso 3, imagen 1 de 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Battery Replacement: paso 5, imagen 1 de 3 ASUS Q302L Battery Replacement: paso 5, imagen 2 de 3 ASUS Q302L Battery Replacement: paso 5, imagen 3 de 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Battery Replacement: paso 6, imagen 1 de 2 ASUS Q302L Battery Replacement: paso 6, imagen 2 de 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
Conclusión
2 personas más completaron esta guía.
khalifa
Miembro Desde 03/02/17
107 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S13-G4, Cagle Spring 2017 Miembro de USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 26
Todo El Tiempo: 5,922
