Introducción
This guide will show you how to remove the wireless card in a few easy steps.
Qué necesitas
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
The wireless card is on the corner of the motherboard next to the speaker. Remove the black tape to reveal the wireless card.
Una persona más ha completado esta guía.
