Saltar al contenido principal
ASUS Portable AiO PT2001 Motherboard Replacement
Qué necesitas
  1. ASUS Portable AiO PT2001 Motherboard Replacement, Back Panel: paso 1, imagen 1 de 3 ASUS Portable AiO PT2001 Motherboard Replacement, Back Panel: paso 1, imagen 2 de 3 ASUS Portable AiO PT2001 Motherboard Replacement, Back Panel: paso 1, imagen 3 de 3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Motherboard Replacement: paso 2, imagen 1 de 3 ASUS Portable AiO PT2001 Motherboard Replacement: paso 2, imagen 2 de 3 ASUS Portable AiO PT2001 Motherboard Replacement: paso 2, imagen 3 de 3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Motherboard Replacement: paso 3, imagen 1 de 3 ASUS Portable AiO PT2001 Motherboard Replacement: paso 3, imagen 2 de 3 ASUS Portable AiO PT2001 Motherboard Replacement: paso 3, imagen 3 de 3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
  4. ASUS Portable AiO PT2001 Motherboard Replacement, RAM: paso 4, imagen 1 de 2 ASUS Portable AiO PT2001 Motherboard Replacement, RAM: paso 4, imagen 2 de 2
    • Peel off the tape attaching the metal enclosure to the heat sink.
    • Lift the metal enclosure off of the motherboard.
  5. ASUS Portable AiO PT2001 Motherboard Replacement: paso 5, imagen 1 de 3 ASUS Portable AiO PT2001 Motherboard Replacement: paso 5, imagen 2 de 3 ASUS Portable AiO PT2001 Motherboard Replacement: paso 5, imagen 3 de 3
    • Pull the jaws of the white plastic frame apart. This will pop the front of the RAM up.
    • Gently lift the front edge of the RAM.
    • Pull the RAM out and up.
  6. ASUS Portable AiO PT2001 Motherboard Replacement, Wireless Card: paso 6, imagen 1 de 1
    • The wireless card is on the corner of the motherboard next to the speaker. Remove the black tape to reveal the wireless card.
  7. ASUS Portable AiO PT2001 Motherboard Replacement: paso 7, imagen 1 de 2 ASUS Portable AiO PT2001 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the 3.5 mm Phillips #1 screw from the wireless card.
    • Remove the connectors by pulling straight up on their ends.
  8. ASUS Portable AiO PT2001 Motherboard Replacement: paso 8, imagen 1 de 2 ASUS Portable AiO PT2001 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the wireless card from the casing by lifting up then pulling out.
    • The wireless card is fragile. Be careful when pulling it out of the casing.
  9. ASUS Portable AiO PT2001 Motherboard Replacement, Heat Sink and Fan: paso 9, imagen 1 de 2 ASUS Portable AiO PT2001 Motherboard Replacement, Heat Sink and Fan: paso 9, imagen 2 de 2
    • Remove the tape attached to the heat sink and the metal enclosure.
    • Lift the metal enclosure off.
  10. ASUS Portable AiO PT2001 Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the four 3.0 mm Phillips #1 screws attaching the heat sink to the motherboard.
    • Remove the three 4.0 mm Phillips #1 screws connecting the fan to the device.
  11. ASUS Portable AiO PT2001 Motherboard Replacement: paso 11, imagen 1 de 1
    • Lift the heat sink and fan assembly off of the device.
    • When putting the heat sink back into place, reapply thermal paste to the underside of the heat sink where it rests on the motherboard.
  12. ASUS Portable AiO PT2001 Motherboard Replacement, Motherboard: paso 12, imagen 1 de 3 ASUS Portable AiO PT2001 Motherboard Replacement, Motherboard: paso 12, imagen 2 de 3 ASUS Portable AiO PT2001 Motherboard Replacement, Motherboard: paso 12, imagen 3 de 3
    • Flip up the locking mechanism and disconnect the three cables using a nylon spudger.
    • Disconnect two more cables by pulling back on the cable using a nylon spudger.
    • Disconnect the battery cable by pulling up on the black connector.
  13. ASUS Portable AiO PT2001 Motherboard Replacement: paso 13, imagen 1 de 2 ASUS Portable AiO PT2001 Motherboard Replacement: paso 13, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the four-5mm screws that hold the hard drive enclosure to the PC.
    • Pull the hard drive away from the motherboard and set it aside.
  14. ASUS Portable AiO PT2001 Motherboard Replacement: paso 14, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the nine-3.5mm screws located at the sides of the motherboard.
    • The screws are denoted by white triangles.
  15. ASUS Portable AiO PT2001 Motherboard Replacement: paso 15, imagen 1 de 1
    • Lift the motherboard off the motherboard standoffs.
    • Remembering the position of the motherboard standoffs makes it easier to position the motherboard when placing it back in the PC.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S17-G5, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 820
