Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
Is your device selfie camera failing to take photos? Probably it is time to get a new front camera. Use this manual to replace the front camera lens assembly.
  1. Insert the plastic opening tool between the edge of the screen and the back cover.
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  3. Use tweezers to remove cover sticker on the dock station.
    • Use tweezers to remove cover sticker on the dock station.
  4. Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
    • Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
  5. Flip the device upwards.
    • Flip the device upwards.
    • Gently push the right side of motherboard down away from the dock station.
    • Do not push the motherboard so hard as it is still attached to a connector. Excessive force applied might cause external damage to it.
  6. Use tweezers to detach the camera from the motherboard. Use tweezers to detach the camera from the motherboard.
    • Use tweezers to detach the camera from the motherboard.
Conclusión
Equipo
I can not get my back off the device at the top of it it doesn't want to complete separate.
Jannell A McDonald - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 88
