Saltar al contenido principal
ASUS Padfone X mini Station Battery Replacement
Qué necesitas
  1. ASUS Padfone X mini Station Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Battery Replacement: paso 2, imagen 1 de 2 ASUS Padfone X mini Station Battery Replacement: paso 2, imagen 2 de 2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Battery Replacement: paso 3, imagen 1 de 3 ASUS Padfone X mini Station Battery Replacement: paso 3, imagen 2 de 3 ASUS Padfone X mini Station Battery Replacement: paso 3, imagen 3 de 3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
Conclusión
Alexzander Pastore
Miembro Desde 10/26/18
389 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 537
