Introducción
Here, the back cover will be removed followed by the secondary back panel. Once this is completed and the motherboard is visible, the vibration motor is accessible and can be replaced.
Qué necesitas
Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
Work your way around the phone until the entire back cover is loose.
Casi Terminas!
Conclusión
