Saltar al contenido principal
ASUS PadFone X Vibration Motor Replacement
Qué necesitas
  1. ASUS PadFone X Vibration Motor Replacement, Vibration Motor: paso 1, imagen 1 de 2 ASUS PadFone X Vibration Motor Replacement, Vibration Motor: paso 1, imagen 2 de 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Vibration Motor Replacement: paso 2, imagen 1 de 2 ASUS PadFone X Vibration Motor Replacement: paso 2, imagen 2 de 2
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Vibration Motor Replacement: paso 3, imagen 1 de 2 ASUS PadFone X Vibration Motor Replacement: paso 3, imagen 2 de 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Vibration Motor Replacement: paso 4, imagen 1 de 1
    • Using a spudger, pry the vibration motor connector from the motherboard.
  5. ASUS PadFone X Vibration Motor Replacement: paso 5, imagen 1 de 1
    • Gently pry the vibration motor upwards using the spudger.
    • The vibration motor is held down by some adhesive, force might be needed to remove it.
Conclusión
Ryan
Miembro Desde 05/14/12
223 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-4, Leahy Fall 2014 Miembro de USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Miembros
5 Guías creadas
Un comentario
That is not the speaker, that is the motor for the vibrate functions...
The speaker is located in the plastic back of the housing near the camera hole.
tee1331 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,310
