Saltar al contenido principal
ASUS PadFone X Station USB Charging Port Replacement
Qué necesitas
  1. ASUS PadFone X Station USB Charging Port Replacement, Back Cover: paso 1, imagen 1 de 2 ASUS PadFone X Station USB Charging Port Replacement, Back Cover: paso 1, imagen 2 de 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: paso 2, imagen 1 de 2 ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: paso 2, imagen 2 de 2
    • Locate CON2002
    • Check water indicator on USB Charging Port
    • A white indicator means there is no water damage. A red indicator means there was water damage.
  3. ASUS PadFone X Station USB Charging Port Replacement, Removing Charging Port: paso 3, imagen 1 de 1
    • Locate and remove three Phillips screws
  4. ASUS PadFone X Station USB Charging Port Replacement, Disconnect E893821: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to disconnect E893821
Conclusión
4 personas más completaron esta guía.
Daniel
Miembro Desde 10/07/14
338 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 7-4, Leahy Fall 2014 Miembro de USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
Miembros de 4
8 Guías creadas
Un comentario
Does anyone have any idea where a replacement USB port can be found. Mine isnt water damaged but rather one of the pins broke off and its hanging out of the cable. Now the phone will not charge.
rich - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,728
