Introducción
You will be looking for water damage on the USB connector and replacing the 1413 USB/ANT docking connector.
Qué necesitas
Using the plastic opening tools, insert it into the edge and pry open.
Use hands to help pull the back off from the front if needed.
Locate the CON101
The white sticker indicates water exposure. White=none, Red=Exposure
Locate P92L on CON1504
Gently peel back and remove plastic tape
These are the antenna wires.
Trace these wires to locate the two antennas.
Locate the two antennas
Desolder the two antenna wires
Una persona más ha completado esta guía.
