Saltar al contenido principal
ASUS PadFone X Battery Replacement
Qué necesitas
  1. ASUS PadFone X Battery Replacement, Remove the back panel.: paso 1, imagen 1 de 2 ASUS PadFone X Battery Replacement, Remove the back panel.: paso 1, imagen 2 de 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Battery Replacement, Remove the screws.: paso 2, imagen 1 de 2 ASUS PadFone X Battery Replacement, Remove the screws.: paso 2, imagen 2 de 2
    • Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: paso 3, imagen 1 de 2 ASUS PadFone X Battery Replacement, Remove the Mid-Frame: paso 3, imagen 2 de 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Battery Replacement, Remove the Battery Connector: paso 4, imagen 1 de 2 ASUS PadFone X Battery Replacement, Remove the Battery Connector: paso 4, imagen 2 de 2
    • Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Battery Replacement, Remove the battery.: paso 5, imagen 1 de 2 ASUS PadFone X Battery Replacement, Remove the battery.: paso 5, imagen 2 de 2
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
Conclusión
4 personas más completaron esta guía.
John Kue
Miembro Desde 10/07/14
379 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-4, Leahy Fall 2014 Miembro de USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 5,101
