Introducción
If your optical drive is damaged or if you wish to upgrade it, this guide will show you how to replace the optical drive. A metal spudger will be a tool used for this guide.
Partes
No se requieren partes.
  1. Push the battery latch. Push the battery latch.
    • Push the battery latch.
  2. Keep the battery latch held while you remove the battery.
    • Keep the battery latch held while you remove the battery.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the one screw above the battery port.
    • Remove the one screw above the battery port.
    • This device was missing its screws on the back cover when we received the device. As a result, we do not know what head type the screws are, along with their lengths.
  5. Use a metal spudger to dislodge the optical drive from the connector.
    • Use a metal spudger to dislodge the optical drive from the connector.
  6. Pull out the optical drive.
    • Pull out the optical drive.
Conclusión
Ruben Lopez
Miembro Desde 05/11/18
399 Reputación
4 Guías creadas
Equipo
IUPUI, Team S1-G4, Baechle Fall 2018 Miembro de IUPUI, Team S1-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G4
3 Miembros
4 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 59
