Saltar al contenido principal
Introducción
This guide will show you how to replace the screen on a Asus N550JK-DS71T laptop.
  1. Turn the laptop off and unplug all cables. Flip over so the bottom is facing you.
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open. Run the spudger along the perimeter of the bottom cover to remove.
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. Remove the three 4mm JIS #0 screws from the battery. Remove the three 4mm JIS #0 screws from the battery.
    • Remove the three 4mm JIS #0 screws from the battery.
  4. Using both hands, lift the battery vertically out of the device. Using both hands, lift the battery vertically out of the device.
    • Using both hands, lift the battery vertically out of the device.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Flip the laptop over with the keyboard facing up.
    • Flip the laptop over with the keyboard facing up.
    • Carefully use the metal spudger to pry both ends of the grey hinge cap.
    • The grey hinge cap may break if not removed carefully.
    • Lift the grey hinge cap to remove.
  7. Remove the eight black 4mm Phillips #1 screws holding display to laptop base. Remove the eight black 4mm Phillips #1 screws holding display to laptop base.
    • Remove the eight black 4mm Phillips #1 screws holding display to laptop base.
  8. Lift the tab on the thick black wire to disconnect the display connector.
    • Lift the tab on the thick black wire to disconnect the display connector.
  9. Remove the thin black and white wire connectors from the Wi-Fi card. The white wire should be above the black wire.
    • Remove the thin black and white wire connectors from the Wi-Fi card.
    • The white wire should be above the black wire.
  10. Open then close the laptop to separate the metal hinges between display and base. Open the laptop again then gently remove the base of the laptop from the display.
    • Open then close the laptop to separate the metal hinges between display and base.
    • Open the laptop again then gently remove the base of the laptop from the display.
  11. Remove the two 4mm black Phillips #0 screws from the bottom of the display. Remove the two 4mm black Phillips #0 screws from the bottom of the display.
    • Remove the two 4mm black Phillips #0 screws from the bottom of the display.
  12. Slide the Spudger down along the edge display.
    • Slide the Spudger down along the edge display.
    • WARNING: Do not pull up as mentioned in this picture! This will destroy the mountings!
  13. Lift the screen from the display to remove.
    • Lift the screen from the display to remove.
Conclusión
3 personas más completaron esta guía.
Steven Hahn
Miembro Desde 29/01/18
758 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S5-G1, Passmore Spring 2018 Miembro de USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 27
Últimos 30 Días: 173
Todo El Tiempo: 1,500
