Introducción
This guide is for battery’s replacement. The guide follows a step-by-step sequence to take out the back panel, unplug cables and replace the batter. The battery type is 6760mAh Li-polymer with 10 hours battery life.
Qué necesitas
Unplug the charger and remove any memory card you may have in the device.
Wedge the plastic opening tool between the front and back cover on every side.
Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
Once disconnected, remove the back cover from the device screen.
5 personas más completaron esta guía.
